I have not tried the "extra clutch" in any AX4N rebuild, but in my rebuild. I replaced all the soft parts; clutches, gaskets, seals, sealing rings, o-rings, bushings, and filter. There is a Sonnex update for the 1-2 bump problem that some will experience, it's called a boost valve. I also replaced all solenoids, including the EPC ( Electronic pressure control ) and adjusted the pressure up just the slightest bit to make a nice firm shift on hard acceleration. And I used ( my rebuilder used wink ) the Trans-Go correctional shift kit, with some of his own modifications. We also remanufactured the Torque Converter, Replaced the forward drum that the OD band rides on,and ran an external cooler. And it shifts killer. Like my plates read. It is 1HOTSHO thumb
