Liquid_force
This trans has always had a hard 1-2 shift when it's cold. Otherwise it USUALLY drives ok, but has had the occasional "things that make you go hmmm".
For the last few weeks it has had a tendency to leak some trans fluid when it gets hot (3x in a month iirc), but never shifted in an unusual manner.
Last time it leaked I thought I noticed some shifting hiccups. I chkd fluid level and it was good. Drove it on the hwy for 30 mi or so at 75-80 then sat idling at a toll booth for several mins. I noticed quite a bit of smoke from under the car and assumed more leaking. Drove another few miles, idled, more smoke, drove a few more mi home.
Immediately chkd under the car and found a 3-4" puddle already.
I would like to get some info on trans repair/replacement options (assuming the problem is something that will require trans removal). I've been happy with the car and can afford to spend SOME money on it to keep it on the road.
Should I be thinking rebuild? Appx cost?
How much $$ could be saved by removing/installing myself?
Is that a job an average home mechanic can pull off w/a helper and req'd tools?
I do almost all my own repairs, but know next to nothing about auto trans'.
Last time I had one go belly up I installed a T-5 (10 yrs ago).
I plan on getting a dx from a local transmission shop, but I'm going on the assumption I have a serious problem and want to be as prepared as possible so the shop recognizes I have a clue.
