Tranny Mount
JCU
North Eastern PA
Just curious if anyone here has driven their SHO with a broken tranny mount. If so, how did it drive and feel? Did you get some vibrations at certain rpms? Also, has anyone replaced their tranny mount. Just curious if it is a big project like everything else that is done on this car.
Finally, the last problem with this car is as follows: If I am driving normally with little throttle, the car will reach certain rpms/mph where it feels as if it bucks and stumbles a bit. This is solved if I give it more throttle. Afriend of mine is a service mgr at a Ford dealership and he ran the car on the diagnostic comp and the only problem that came up was a O2 sensor. The problem is still there though. As a result of what the results were on the comp, I would assume that it is something minor such as a fuel filter, plugs, etc.., Anyone else have this problem before?
MilTownSHO
Horicon, WI
The sometimes stubling feeling I used to feel. Haven't noticed it lately. The new thing is the car will vibrate for a second during idle and then it will go away, come back, go away...you get the idea. I swear when we got the car you couldn't even hear it running...now, I don't know?! shrug I can't wait to get the cams welded so we won't have to worry about that agian!
Ian Macoomb
Ottawa, Ontario, Canada
MilTownSHO:
Any stumbling noticed at idle is a bad coil. Especially if it is intermittent.
David Carpenter
