Tranny grinding!
Devin
3.Slow
Pacific Northwest
So I thought my grinding issue was gone but it appears I was wrong. When I accellerate forward (unsure if backwards is the same) I feel, more than hear, a grinding. It feels like I'm driving over the grating on a draw bridge. I got my axles from Raxles a bit under 7K ago so I hope it isn't then, but then again I have strange feeling it might be the tranny itself. Any ideas? It is not always present, but it happens pretty much every time I take her out.
Devin
3.Slow
Pacific Northwest
It leaked out when I pulled it, and was up to the threads. It was a nice red color. It also is 7K old.
I used redline synthetic in it. Is it worth swapping the fluid for a known good fluid?
edit:
I got a bad grinding when reversing and turning, and I've gotten it now slowing down in gear. So the only time I have not noticed it is being still and clutch-in.
Devin
3.Slow
Pacific Northwest
Okay, so now when reversing it sounds like I'm dragging thye tranny on the concrete. It sounds horrible. Forward sounds like a light grinding every now and again still. I'm now waiting for my tranny to hop
out of the car flip me off and run off.
ckinney89sho
fo SHO
NY
how about your TOB or a bad PP. they make a grinding after so long of bein bad.
DemonNeno
SHOCAGO Freak
Skokie, IL
Have you jacked up the car and looked for any bad front end parts? Jack up both front wheels, set it on stands and toss it in neutral. Grab the spring with one hand and give each wheel a good spin. If you feel any grinding, you're bearing is shot. Keep in mind, brake pads gently sweeping the rotor will give a little something you'll notice, too. Check both sides before convincing yourself something is wrong.
Give your wheels a good wiggle. Up and down (commonly bearing play), left and right (bad outer tie rod or really bad inner tie rod.. I'll explain in a sec) and finally grab the Drivers wheel on the lower left corner of your wheel (left being the same side as your left shoulder) by the inner sidewall and the outer sidewall and shake it. Grab your lower right corner on the passenger side to check it out.
You could have a bad bearing, may have a oblonged spindle with the balljoints end hitting an ABS ring or axle. You may have a caliper missing the lower bolt, causing it to push up into your wheel.. This stays like that long enough and it can bend your intact slide pin and keep it pressed against your wheel.
And about that inner tie rod... The most accurate way of checking inners is by placing them on caster plates that move. With the vehicles stationary weight on the outer tie rod, it'll free up the tension a hanging wheel places on the inner tie rod. Thus, your inner tie rod (which is basically a balljoint with a really long shaft) is tension-free, running straight along from your outer to your rack and can be checked for the slightest play.
It can be so many different things, you should stop pointing your finger at your trans and REALLY check your car dude.
Hope this helps!
Devin
3.Slow
Pacific Northwest
Sure it's the tranny? Maybe a wheel bearing or brakes grinding?
I never followed up on this thread, but you were spot on. The brakes fell off a good week later. All fixed now though. Locktite next time!
kikkinasphalt
Wrrrrrrrr
Missouri
the brakes fell off a week later?
and people blame the car for being unreliable..:braincramp:
