torque converter lock up
Jim Dow
Maine
My 93 atx is locking the torque converter at slow speeds in overdrive.This causes some drivability problems.I have done some research here and see the vss maybe the culprit.If I touch the brake lightly the converter will unlock as it should.Is there a way to wire a togle switch into this brake switch so I can controll it?Lookingfor a cheap fix.Jim
stevetatro
Cincinnati, Ohio
If you do a search you'll find people describe ways to replace the VSS from the top, from the bottom, and from the passenger side wheel well.
Good luck.
