torqe converter question
shonutt
Yeah I Got Rice
Saginaw MICHIGAN
ok im looking inn to buying a beautiful satin 99 sho .. it has 93 K on the clock it has new welded cam and fresh heads ..do to the cam failure .. car runs idles and drives beautifully .. but the check engine light is on .. was scanned at whimpys trans shop they said it had a torqe converter code ... plus an o2 sensor code .. ... care seems to drive fine ... any reason or causes that could make this happen ... this car had been sitting for 2 years prior ... is it somthing to be conserned with ?any advise would be awsome
There are numerous possibilities - what are the exact codes that exist? (btw, the auto parts store should scan it for free, if you need to have it done again to get the details.)
E1 v2
crash tested
holiday inn
Any idea how old the tranny fluid and filter are? A fluid flush and filter may be in order.
shonutt
Yeah I Got Rice
Saginaw MICHIGAN
the fluid is factory original .. and filter ... the car had been sitting for over 2 years .. i was told ... i havent yet had a chance to rescan ... the car dives beautiful even at fully operating temp... would have never know there was an issue until the ses came on .. and saw it there with the 02 sensor ..code.. i was told a harnees on top of the tranny may have not been pluged in uppon the reassebly of the motor ... so i dunno
E1 v2
crash tested
holiday inn
Way overdue for a fluid change and filter. Every 30,000 miles is what is recommended.
Unplugged plug after engine work is possible, but one which only throws a TQ Converter code and still drives beautifully is very unlikely.
I'd change the fluid and filter, clear the codes, drive the car for a while and see if the codes stay away.
ThatShoGuy
michigan
watch out it isnt always good to just change the fluid if its really over due. like if it has 100k on that fluid i wouldnt change it!
alot of the clutch material is in the fluid, doing so may **** your trans!
Mr Anonymous
Tire Wall
If it's a P1744 code all the fresh fluid in the world isn't gonna fix it. You'll need a new converter and converter seal at a minimum, and probably a stator support which means disassembling the tranny which means just get a full rebuild.
