Top Speed Diagnosis
BeatDaSHO
Hatboro, Pennsylvania
So please don't flame me for this but I wanted to test out the range of my SHO. I recently sold an 89 SHO. Last year, I took it on this one onramp and there is this big stretch of flat highway where there are no cops and no one travels at night. So I ran through the gears. I hit 135 on it easily by the time the exit ramp came. I sold that SHO and picked up my brothers 89 SHO. We raced last year up til 130 and they are both dead even. None the less, I picked this up and tonight I tested it on the same onramp. I eased into it and 1st pulled great, second pulled great, third pulled great........then the switch to 4th gear, it pulled sooooooo slow. I couldn't pull any faster than 110. It just stayed there. I held it there for over 5 seconds and it wouldn't pull anymore. I have no idea what's goin on. This car has had every bit of maintenance work to it, 60k done about 15,000 ago, i just replaced the air filter and tps (code came up for that)......I have no idea what is going on. Any ideas? Please help. Thanks.
Greg
revhardSHO
Seattle, WA
DHMag said:
plugs and wires
before changing to Taylor wires and hotter plugs, i couldnt get a bit over 115
What are you running for plugs? I was under the impression there was one and only one plug made for the SHO. As for the wires, just make sure you get OEM quality replacement. :)
DHMag
Free At Last
InCahoots, Texas
Bosch Supers. there are many plugs available for every engine out there, the SHO is no exception. it all depends on what the engine likes. in my case, i overheated the 32PPs, so i switched to the Bosch Super which is 2 steps hotter. been running them for about 6 months(6K miles) and love them. ill be taking them out this week to check them.
BeatDaSHO
The plugs and wires are only 15,000 miles old. A FULL 60k was completed 15,000 miles ago. The wires are motorcraft and the plugs are agsp32pp plugs. The fuel filter is the original though but would that allow GREAT performance from 0-110 mph and then totally stop? This car pulls reallll hard to 110 mph and then won't go any further. Now, if the timing belt skipped a tooth, would this allow great performance to 110 and then stop? I would think that it would be down on power in the whole powerband. What else do you guys think? Thanks a lot.
Greg
SHO_Driver
Montreal, QC
Did you say the fuel filter is original, meaning never been changed? The one they installed in 89? If so that can't be any good for the fuel pump.
Slo-Sho
It wasn't me!
Crossroads, CNY
Yeah, that's what I was thinking. It's a $9 part and takes about 5 minutes to change with a flathead screwdriver. :doh:
But wait, fuel filters don't get dirty. :headbang:
GEORGE 1992
LONG ISLAND NY
Very funny! And also very true!!! :salute:
DHMag
Free At Last
InCahoots, Texas
Greg
i overheated my 32PPs in less than 4K miles after my 60K.
Joe'sSHO
Winsted, CT
I don't think this is something that's been addressed yet. What about your speedometer? SHO guages are notoriously bad and I wouldn't be surprised if it's just reading incorrectly over 90mph. My red 90 used to read fine up untill 90mph then it would take almost all of 4th gear to get the speedo to read 100mph. I know the speedo was bad b/c i swapped the 90's engine and trans. into a 93 and had it up to 120+. If it feels like it's still pulling well (or at least feels like it's is still pulling at all) in 4th I would think you just have a bad gauge. Just my 2 cents. Hope you figure it out. :thumb:
DHMag
Free At Last
InCahoots, Texas
anarchy04 said:
yeah, try watching the tach instead of the speedo
the tach isnt accurate either.
as my dad always says, "Ford is not in the business of making critical data acquistion gauges, just cars."
