Tokico's/ Monroe's
SASHO91
Zoom Zoom
San Antonio,TX
Well one of my rear Tokico's is leaking. With them out of the picture, the only other real option (for me-Koni's not yet) is Monroe Sensatracs. But I'm concerned about running this combo. I've driven a cut Moog/Sensatrac SHO before and it rode nice. It could bottom the front suspension under a hard bump, but it had 1.5 off the front and 1 coil off the rear as well(which is what my setup consists of).
Since my car is lighter than stock, I would think this setup would probably work okay. It will obviously not be ideal, but it is no track car either.
Input?
SASHO91
Zoom Zoom
San Antonio,TX
I know they are, as I have run both sets. The Monroe's are not all that soft, and the variable valving, I think, would be enough to keep the rear semi-firm in the corners. Again, plus the fact that the car is lighter only helps matters.
jon93
Philadelphia Region
The monroes will work but don't expect them to last over 30-50k miles. Don't waste your money or time if you are getting koni's eventually, just get them now!
Jonny Cash
Good boy
Hollywood, FL
Your other struts are good? Have you contacted tokico for a rebuild? I had my bilsteins revalved for 60.
SASHO91
Zoom Zoom
San Antonio,TX
A rebuild? Didn't know that was possible. I know the warranty is gone (but that replaces the damage strut) as they are no longer made. And that the inserts are no longer made as well.
I would assume that some of their internals are compatible with other struts.
I figured since they stopped making struts and inserts that they just cut off all ties with these specific struts.
