I recently ordered the aluminum TOB bushings from Sho Nut. There are 2 different bushings in the set- an upper and a lower. Which is which?
One of them is longer than the other and I think is slightly thinner than the shorter one.
I assume that the shorter one is the lower bushing by looking at the inside of the bellhousing. If that is correct it appears that it is going to be a press fit.
Does anyone know for sure?
Thanks in advance.
Chris
Thanks in advance.
Chris
