tire size vs. rim
jspec23
Lowell, Ma
Quick question, I just inherited 4 goodyear eagles with only about 5k on them.
size : 225 x 60 x 16
will they fit on the stock slicers?
SinisterSHO
Rust free
630, IL
Yes they will. They will be a little bit taller than the stock 215/60/16, but they will fit. Alot of people run 225/55/16, which is what I have on my car. They're about the same height as the stock tires.
jspec23
Lowell, Ma
That's cool, ya they were free and I needed tires bad, so not a bad deal. Thanks
HighSpeed
Low Drag
Chicago, IL
You mean wider?
Just watch out for the rear struts, that may rub on occasion.
K-Dawg
Treasure Coast, FL
225/60/16 will be taller and wider than the stock 215/60/16. I believe some people have reported rubbing on the spring perch with that size tire.
wuzzzer
MN Moderator
St Cloud, Minnesota
They'll be about 3/5ths of an inch taller than stock.
Your acceleration will be slightly slower with taller tires.
Your speedometer will read 1.8% slower than you are actually going.
(Example: If your speedometer says you're going 60 you'll actually be going 61.1mph)
They'll fit the wheels fine though.
