1. I am trying to reassemble my shortblock, but without a helms I am a little in the dark. When I gap the CPS to .030, I gapped it from the flat rim of the timing belt sprocket. Is that the correct way?
2. Do I need to lubricate the surface between the oil pump and crank shaft?
3. If I can depress the timing chain tensioner with my finger, does that mean it is bad?
