Tie rod ends
Markus
Ottawa, Ontario, Canada
I cannot remove the jam nut on my original tie rod end. I have tried heating it with a propane torch with no effect. Any help on how to remove this is appreciated.
Ishodu
You are using two wrenches at once? If not use them with each other, one to loosen the nut the other to loosen the tie rod. Other than than I never had a problem with them.
shojuan
sunny San Juan Bautista,
Those can be a bear when they've never been apart before. Apart from making sure to use a second wrench to hold the tie rod end in place use a length of pipe as a cheater bar on the wrench you're using on the nut. Also it might help to clean the dirt out of the small gap between the jam nut and tie rod end and get some pb blaster in there. Clean the threads on the other end and spray there as well. More heat on that nut should really help too if you're not getting it hot enough. You can always use MAPP gas to get that nut glowing.
When you reinstall, be sure to smear some grease on the clean threads where the jam nut will be resting against the tie rod end. This will prevent problems in the future and basic hand wrenches will be good enough then.
UnsungZero
Carol Stream, IL
Is it Frozen or Just Spinning?
if frozen....try MAP gas propane sux.
if it's spinning you will need jam a picklefork between the rod and knuckle then heat the nut and loosen.
