Liquid_force
For some reason this evening I decided to basically take it WOT from the toll booth getting up to speed on the turnpike.
I noticed the battery light flicker around the 1-2 shift (close to 6k rpm). Soon after that I noticed the climate control had turned off, then I noticed the dash lights were unusually bright.
So I'm immediately thinking voltage regulator. It seemed strange to fail all at once though.
I had about 20 min left on the drive home. I was able to determine that the high voltage kicked in at 2500-3k rpm, and it would drop back to something in the "normal" range at about 1800.
Took some measurements when I got home.
At idle it was just under 13v, like 12.95-12.99. Engine off it was 12.5-12.6.
When I revved it it surged to 17v and higher.
I guess my question is do I bother trying to track down just the V reg or would I be better off just replacing the whole alt?
I have located a replacement available locally for $105, after $45 core and $35 discount code. It is a reman.
