Thermostat Housing Leak
autobahnsho
SHO Victim
NY for now, WY for real
I pulled the intake last week to check compression. I must have bumped the thermostat housing, because AFTER I got everything back together and out of the garage it was gushing coolant.
I know that a garage here known for SHODDY work put a thermostat in before I bought the car.
After dealing with a broken stud, I've tried to seal it back up right and I still have a small leak.
The o-ring isn't an "o" so much as a flat-on-two-sides rectangle. I checked the only local American parts store and they don't carry it.
I tried using it with and without: rtv on the edges of the housing, a gasket I cut, and nothing at all.
Both times it's started leaking after the initial sealup and test drive, and it leaks the NEXT time I run the car. I assume it's expanding/ contracting.
What can I do to seal it up until I can get a new o-ring??
Thanks,
My local NAPA has these in stock on a hook. I don't think this a SHO specific part.
autobahnsho
SHO Victim
Thanks, it probably isn't. I'm limited here on options on getting parts, though. :rant:
Since it broke loose again Sunday I could open it up and take it into a German store, to see if they have the right size. But I went ahead and ordered it on Autozone.
Another coupla days of riding my bike to work, I guess. Too bad I'm getting really used to that. :madflame: At least it's only a mile and the weather has been ok. :thumb:
autobahnsho
SHO Victim
FINALLY got 'er patched up.
The O-ring was in my mail early this week, but I started to take the top nut off and the stupid stud pulls out of the housing.
So this morning I took it in- I had stripped out the bottom nut somehow, so I ended up cutting that stud off, then drilled, re-tapped, and re-tapped the top one.
Instead of studs/nuts I put some bolts through. I was careful to not tighten too much, and it looks like it's done leaking for a while.
What a drama!
My wife is so sick of it we're going used-car ($3800 or less! Can't get a loan. :madflame: ) shopping today.
May you all never suffer broken studs. :cool:
myculito
