Tensioner Question
SHOByrds
Virginia
I forgot to put the bolt and ring back on the tensioner for the Alternator belt.....after a couple hundred miles it was squeaking and worn....
So my question is where can i get another ring that goes behind the bolt?? or could i use something else
92greenmtx
Kasota, MN
I assume your referring to your 92? I don't understand what bolt and ring you are referencing. There are three bolts that hold the tensioner to the motor, the pulley bolt, and the bolt that sets the tension. I don't get which one you could leave out and still have it work for 200 miles?
SHOByrds
Virginia
yeap my 92
The belt goes on the alternator the ac and the crankshaft....also is rest against a tensioner that is smooth and silver....this is what i forgot to secure...
It has one bolt and a cup washer to keep it secure same as the other belt tensioner
92greenmtx
Kasota, MN
Im getting one from the junk yard
how do you know when the bearing goes bad?
Sorry for the delay, its been a long weekend :) yes, if you hold the pulley in your hand and spin it, it should feel smooth (not grainy). A little stiff to turn is ok. Once torqued to the motor grab it and check for lateral play. (there should be none)
