Mike Stitzer
OK, I was finished buttoning up the SHO after replacing the water pump, CPS and timing belt, when I look on my workbench and see TWO identical o-rings. They are the size of the one from the tube that lays in the valley of the engine on the crossover tube. One looks old, one looks new. I swear I installed a new one from the Felpro water pump kit on the tube before I replace the wp. Yet I'm also pretty sure the felpro kit didn't come with two of these thicker o-rings. Did I just spend several evenings assembling the car for nothing?
I blew into the radiator as hard as I could listening for air leaks and heard nothing, and it had tons of pressure when I pulled away from it. Does this mean I did install the o-ring. I didn't put coolant in it yet so yes, I could take it all back apart again if I have to.
One other thing. I'm pulling the intake to replace the valve cover gaskets. Is it possible to get to this crossover tube from the thermostat side? Can I pull it out of the water pump inlet from the drivers side?
Mike
Mike
