taking horns out with bbb install
loboreno
NY
I searched and couldn't find answer .... if I take horns out does the spacing get messed up? Or do u use two gaskets?
intimdatr
Got Cams?
Jefferson City, Missouri
Ok great! Thank you for the help
When putting every thing back together make sure the gasket surfaces are CLEAN of any debris. I use a razor to get most of it off and then finish off with a soft/medium wire brush on a drill to ensure its a perfect surface and never had any issues. No RTV ever.
Irish Pride
Irish Inside
MusicCityUSA
Do not tighten the coupler clamps until you have the intake mounted back on the engine. If you tighten the clamps first the intake will not line up correct. Just get the intake together but leave the clamps loose.
