Motoman991
Has anyone here taken the engine out of their sho without using a car lift? Is there enough room to get the engine out using floor jacks or a ramps? I really need to get my sho fixed.
Motoman991 said:Do you know how they did it with far less?
+1 albeit the jackstands were a little beefer than what you get at Habor Freght. Have done it twice in the last three years this way. But the engine is coming out the bottom. Engine crane is a mustnaval-avi8or said:I have done it with a engine hoist, two jack stands and a floor jack.
engine hoist used to raise car.
floor jacks for peice of mind
floor jack to roll engine/tranny/subframe out.
SHOWHAT9 said:+1 albeit the jackstands were a little beefer than what you get at Habor Freght. Have done it twice in the last three years this way. But the engine is coming out the bottom. Engine crane is a must
Once you have the nose off, use good solid chain and cut a hole at each end of the bumper support if you can't find any other that will balance, run the chain through it, attach to crane and pull her up. insert tall jackstands where you want em and let er down.Motoman991 said:I have a 3 ton engine hoist, plently of jack stands and two 3.5 ton floor jacks.
Where do you lift the car using the engine hoist?
SHOZ123 said:I want pics......
YAHTEC said:Very interesting... Did you make a video of you starting the car than dancing when it ran? haha.
Mr Anonymous said:A few people (Eric L., Carter F. for starters) have done it with far less.
