Tail lights out?
TJS461
Western Mich
So last night I was informed my tail lights are out. '16 SHO has LED tail lights. Brake, turns, reverse all work.
Fuse (#15 under the dash) is good. Any others I should look for?
Also, using Innova 5160 scanning the BCM turns up no DTCs. When running the diagnostics though, the lights DO come on.
Tried running live data to operate them but I'm not familiar enough with the tester yet to get to the right screen.
So... headlight switch? When using the 5160 I tried going to headlight control module and it said it couldn't read, bad connection etc.
Any other testing or troubleshooting I need to be looking at?
Thanks.
Texas Marauder
Lone Star State
The headlight switch carries no load. It sends a ground signal to the SCCM which then sends a signal over the HS can to the BCM which then turns the tail lights on.
The tail light assemblies appear to be modules themselves. Pin 6 seems to be a control from the BCM to turn on the tail light but, I can't find that in any diagrams. Same wire on left and right tail light connectors. I would check that for voltage, probably 5V.
1793559895872
1793559994226
1793560073593
TJS461
Western Mich
Thanks so much for the help. However, I don’t believe pin 6 was the correct one in this instance. I checked and had that same voltage with the lights switched both on and off. Digging around the wiring diagrams I noticed wire 3 is the same colors wire, just reversed (2-color wire) and it mentioned another fuse. Tried that one and got no voltage. Turned out it was the fuse after all.
Thanks again. I really appreciate the response, and especially the wiring diagram.
What i really dont understand though is why the scan tool didn't pick up the fault...
Texas Marauder
Lone Star State
Glad you got it figured out.
I don't understand why the same fuse seems to power reverse and tail lights and you said the reverse lights worked.
raymo23
