Tach needle stuck below 0
Joe'sSHO
Winsted, CT
Recently I disconnected my cruise control due to the line sticking the throttle open. Today the line somehow caught on the throttle and stuck it open. The tach reved out past 8000 before I was able to cut the engine. I took the cruise back off and secured it so this wouldn't happen again, but now when I start the car the tach needle goes below the 0 and gets caught on the plastic piece that is supposed to stop it. Thus I now have no tachomoter. Is there any way I can get it unstuck w/o taking off the dash (my tools at school are very limited)? And if I have to take off the dash, should I just push the needle around back to 0? Will it mess with the accuracy of the rpms? Thanks.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
The "Old School" trick is to wind the car up to redline and it usually grabs the needle and pulls it back. Warm her up first, please :)
Joe'sSHO
Winsted, CT
Thanks! One question though, how long shoud I rev it? I don't want to be sitting there for 30 seconds with the pedal to the floor waiting for something to happen. Does it grab the needle quickly (i.e. after you pass 8000)? Thanks again, I'm glad there is something I can try before I just have to take the dash off. :D
SHO--ripper
928 Euro
winsted,CT
Joe do you have the rev limiter in "ol reddy"? If sho hit it in first and it should set the tach straight. Lighting them up the whole 1/4 mile headbang
N20 hail
5.0's and WRX's running mid-high 16's at the track finger
Smoking rice with the tires
lol
I'm going again on Sat. hopefully i'll have some good e.t's this time. I'm going to eliminate the A/C compressor, and have the N20 switch on the steering wheel so i don't have to go "up in smoke"
Joe'sSHO
Winsted, CT
No Chris, it is stuck under the plastic piece @0. It can't move up b/c it's stuck. Hope you're nitrous runs prove better than you're last outing.
Whiner
Cptn. Realistic
Roseville, MI
lol
bs bs bs wrx high 16's?!? bs
Joe'sSHO
Winsted, CT
Yeah, I was surprised to hear that a WRX were running mid 16's. She must have really bogged off the line! You should be able to launch those things @ like 6000 w/o wheelspin!
ROB L
RI
I had a 1989 that the tach was stuck, AND it was below the pin.
Take itout after it is warmed up, and get into 2nd gear than slam it :) when it hits close to redline the tach just kicked in :) :) Try it, it worked for me.
ROB
Joe'sSHO
Winsted, CT
I took the advice, warmed up the car and nailed it in neutral. Lo and behold, it grabbed the needle back and now I have a tach again. Thanks a lot for the advice. I'm glad I didn't just take the dash off. And yes, I agree not all girls are bad drivers. thumb
