tach doesn't work, engine temp all the hot
HELLBENT93
Phoenix, Az USA
im rather confused, i get in my car and turn the key to the on position and i notice that the only gauge light that comes on is the battery light. The parking brake was set and that light didn't come on and neither did the oil pressure or check engine light all the usual stuff that lights up when u start a car didn't light up. It started up fine the i noticed that the tach gauge doesn't work either, it just rests at zero rpm. And it said that the egine temp is all the way hot? It was just fine the other day. Anyone got any ideas?
91MochaSHO
Ashford, CT
Check the connections to the gauge cluster behind the unit. My 1990 SLO came partly disconnected and the temp gauge stopped working. Could be a bad ground.
91MochaSHO
Ashford, CT
Your gonna have to disconnect the speedo cable. Then you have to remove the black trim piece and pull the gauge cluster out. The connections are behind the cluster on both sides. Its very tight!
