Switching Sunshades
MilTownSHO
Horicon, WI
Tonight I was switching the sunshades from the 93 to the 92 and the fuse blew twice that controls the clock time, radio, courtesy lights, etc. I'm pretty sure it was the shades doing it. That's the only thing I could figure out, neither one of the mirrors lit up. The connection is the same but is there something different?
Why doesn't the mirror light from the 93 work in the 92? Anything I can do? Could this blow a fuse?
<small>[ December 23, 2003, 04:12 AM: Message edited by: MilTownSHO ]</small>
jelloslug
Digital
Greenville, SC
When you say sun shade I'm assuming you are talking about the sun visors, or are you actually taking about the sun shade for the sun roof? If it's the visors, the ones from the '93 should work fine. I had '93 visors in my '90 for a while with no problems. Most likely you have an internal short inside on of the visors. Pull them back down and check the wire that comes throught the spring post to see if its been nicked. If it's internal it will be a PITA to open them up but its possable.
MilTownSHO
Horicon, WI
Yes, I meant the visors, I was really tired last night when I got home. The weird part was the visors that were in the 92 worked fine and when the visors were in the 93 they worked fine, but now when I installed the 93 visors in the 92, the fuse blows and they don't light up?! So maybe it is a short all the sudden, I'll have to check it out, thank you!
