sunroof visor removal
SUPERMN
DELAWARE
can the sunroof visor be taken out with the sunroof closed or does it need to be open?? i need to remove it and clean it up cause it has a bunch of spots were it looks like the fabric has melted, guessing from the heat of the sun?
hawkeye18
Sorta cares
Norfolk, VA
From the service manual:
1. To remove roof sliding outer glass panel, remove three roof sliding panel opening shield (50988) front retaining screws.
2. Slide roof sliding panel opening shield and roof sliding panel headlining fully rearward to expose six roof sliding outer glass panel retaining bolts (three each side).
3. To remove roof sliding panel headlining, remove roof sliding outer glass panel retaining bolts and washers.
4. Push glass up from inside vehicle and remove. Take care not to scratch glass or roof paint.
5. Slide roof sliding panel opening shield and roof sliding panel headlining forward halfway across roof sliding panel opening shield opening.
6. Lift roof sliding panel opening shield to clear roof sliding panel headlining.
7. Push roof sliding panel opening shield fully rearward.
8. Slide roof sliding panel headlining fully forward.
9. Lift front on roof sliding panel headlining, slide forward and rotate 90 degrees to remove.
SUPERMN
DELAWARE
id be happy just scraping the old bubbling material off. maybe i can do it with it still attached??
Danz13
ATX Sho Member
Rancho Cordova, California
To get all of mine off I had to take it out, and was a real pain to scrape all that stuff off. I used lots of paint thinner to soften the glue
VNUK1SHO
Alter Ego
Champlin,Minnesota
Just did it today! Soak that Bi@#h in the bath tub in HOT water for 35 to 45 minutes then it comes right off no problem. Yeah I took mine out through the bottom too but am now having trouble gettin it back in!!
Danz13
ATX Sho Member
Youre probably going to have to install it through the top, so you have to remove the sun roof glass... make sure you DONT STRIP the screws, cause it will suck a lot
StillDyl
Oregon
mines pretty scary and destroyed.
im highly considering just destroying it and ripping it out. ha
38SHO
#1 Oil Abuser
North Palm Beach
mines ripped, whenever I'm waiting I scratch pieces of it off haha... just trying to get it back to black plastic if anything, but it needs more attention
also i've had my sunroof opened before, but the last couple times I used it it would kind of bind... and my cover piece is also bound up and not right..... its like its off track or something.... Ireally need to tear into it and see what happened. I've just never messed with sunroofs before and I don't want to get into something that will take me more then a day....
thx for sharing some instructions
diagrams or pictures would be great, guess I"ll have to search a lot
TopGunnYFZ
Livonia, MI
Mine was all messed up in my 1G i just got mad sitting in traffic one day and yanked it right out LOL Worked real good quick and easy....Although my 1G isnt considered MINT condition so it didnt matter to me how it came out, although it came out clean
