Hey forum:
Thought I would pass on my experience with this problem. I haven't done a thread search, so others may have had this problem.
I had a water problem that soaked into the sound insulation under the right rear back seat and into the floorboard pan for that seat. Tracing the leak up resulted in the conclusion that the leak was in the door seal or roof somewhere. 3M makes this black weatherstripping glue that works very well. It comes in a red tube. The door seal wasn't the issue. I gently pulled back the headliner. The sunroof pan has a drain spigot with a drain tube that is not secured by anything not even a hoseclamp. The drain hose pulled back and off the spigot causing water to run down the inside panels and to settle under the back seat. Its a leak that is not apparent but looks likely to recur in other SHO's. Problem is solved. I had to lose the sound insulation (moldy) and clean with much disinfectant, but the smell is remedied. Now I've got to track down the one-way panel fasteners that all broke, of course. Noise levels are uneffected. I have a 94, ATX, green, 130K, no rust (yet).
FWIW.
Pillarian.
FWIW.
Pillarian.
