oldyak
I am concerned about transmitting harshness into the structure by going to aluminum bushings...please advise b-4 I buy..plastic or aluminum?
I also have the Gen. III rear bushings all around on my '94, too. Prior to that I had run aluminum but found that the ride was a little too harsh for my liking.LOUDSHO92 said:I have the rear Gen3 bushings in mine. I like them. They are an upgrade to stock but not as harsh as Aluminum bushings. If you dont want the harshness I would recommend those.
What price are they going for now BTW?Rockledge said:I also have the Gen. III rear bushings all around on my '94
And using new hardware all around is a good idea, too. A couple of subframe recall kits will take care of that.ml98188 said:Whichever way you go be sure to get it to a frame/alignment shop afterwards cause the SF most likely need squaring up.
And I guess when the person doing the complaining is a dirty from working on his Harley helps a little too!
Josh at http://www.shonutperformance.com sells a complete set of 4 upper and lower Gen 3+ rear subframe bushings for $114.40.etc1006 said:What price are they going for now BTW?
Are you sure the subframe moved on its own and wasn't moved during a clutch/tranny swap or for an alignment?Minnesho said:my subframe had almost shifted a full inchwith the stock bushings that came from the factory according to the alignment holes up front. i suppose now that i put it to where its supposed to be the steering will be way off, come to think of it the steering wheel was quite crooked before. I just installed the aluminums, but I wont be able to tell you how they ride for a couple days.
Mr Anonymous said:Are you sure the subframe moved on its own and wasn't moved during a clutch/tranny swap or for an alignment?
