subframe bushing bolts
SuperHO
Mental Patient
St. Joe, MI
so my front subframe bushings are loose, but when i go to tighten them, the nuts just spin. is there an easy way to get a wrench in there to hold em in place?
shoon
cliTaurus
Dawson Creek, BC
Peel your carpet back underneath the brake pedal, and look for a big 2.5" rubber plug. If there is no hole / plug see if you can get your hands on a subframe recall kit.
In the meantime, you will probably need to drill a 2 1/2" hole in the floor, (if the subframe recall has not been done already) That will give you access to the spinning nut. There is a detailed picture with measurements where to cut, let me know if you need it and I can try and post it for you.
the nut is supposed to be held in with 2 tabs, but if the tabs bust off the nut will just spin as you mentioned.
Edit:
http://www.shophoenixproject.com/sfb/sfb.htm
Lots of helpful pictures on there too
Silvapain
Limestone, IL
Edit:
The subframe recall doesn't apply to Gen 3's.
Welcome to the V8 section :wave:
If it is the front nuts there is a large opening that you can get to on the inside of the "frame".
Well looking at my '96 RM yesterday with no engine I could look right at them from above. :)
You should be able to get to them from underneath with the air deflector/splash shield off.
