Sub Install fails, Splice not good to do to rear speakers!?!?
SHOntell
**** Rapids, MN US
THE GOODS: Two days ago I purchased a 12" Kicker Comp sub in a box
and a 500 watt 4 channel amp for only $250. Great deal. SO I go to get it installed by some guys and I find out my dash is goofy and difficult to get off.
PROBLEM: So I go to Circuit City to get the head unit popped out and the car audio guy tells me there are no RCA's behind and I need to get the converter. NO Problem I say. I asked him if I could splice from the rear speakers and run to my new amp,(that is what has been posted so I relayed that info.)and he said NO!! Because the amp already has a built in crossover, splicing would not give the best signal to the new amp and not produce the best sound. Plus he said the rear speackers would have less power due to splice??
He said the best way to do it is to splice directly behind head unit before it hits the amp. Then you will be getting the full signal without any crossover. That was going to be a chore because there are so many damn wires back there I had no idea what to do.
RESULT. I Returned my sub and other equipment and got 2 nice kenwood door speakers to replace the crappy ones I have. Those sound great but I am bumbed about the sub issue. Let me know what you think.
Sorry so long, but I needed to get it out.
1997 Ebony Satin
K&N cone filter
Bullet mufflers
Cincy SHO Bra
wuzzzer
MN Moderator
St Cloud, Minnesota
Okay, #1, Circuit City sucks in my book.
#2 Take your car to any Audio King down in the Mpls/St. Paul area. I can pretty much say that they'll hands down be more knowledgeable than Circuit City will ever be.
SHOntell
**** Rapids, MN US
Hey wuzzzer, so your saying I got some ****** info and should have just spliced off the rear and said screw it. 500 watts pushing a comp. rated 12 inch sub would have been nice. It is a real easy job if I splice from the rear. I guess I got spooked and dont want to mess up my car. The other problem is that I returned the equipment and the guy who can get it for me is out of town until next week and who knows if it will be there!! I am going to pull my hair out,
oh wait, I don't have any!!
J
Jay97SHO
Guest
You CAN splice into the rear speaker wires. I did it to my '97. I HAD a bandpass box with two 12" MTX speakers in it. It was nice,but too damn heavy for the car. Made it look like I had a couple dead bodies in the trunk
Have you checked out V8SHO.com? There is a writeup in there about hooking up subs.My biggest problem was running the power cable to the trunk.And,if you splice into the wires,the sound coming from the rear speakers WILL NOT be disturbed .
Good luck!
Jason T.
1997 SHO
V8 power,baby!
73,000 miles(parked for the winter)
White/gray leather
Large,White 7"x12" SHO letters across Windshield
Roush Racing springs waiting to be installed in the spring
Flowmaster 40's/No resonator,and 3.5" slash-cut chrome tips
K&N panel with no sax
otherwise pretty much stock
AIM name:Jay97SHO
NESHOC member
And,now the proud owner of ANOTHER Mocha '91!
Can't wait to get this one driving!It finally RUNS!!!
Ex: 1991 SHO
Mocha with black leather,DynoMax cat-back,no resonator,and K&N panel
SHOntell
**** Rapids, MN US
Now I am really ****** I returned my stuff so fast. OH well, I can still pick up good stuff from this guy. They have a ton of kicker competition, orion & orion HCCA (wow) JL, pioneer, kenwood, xplod, boston etc. I may actually get a smaller sub and put it in because the 12 in the box didn't quite fit under the rear speaker deck so it took up a little more space than I would have liked. Maybe a 10 or a good 8 inch. I will put up a new post if I do the job. I do like my new sound with the Kenwoods in the doors. They are nice.
CMurderSHO
pittsburgh,pa usa
You got bad info from the circuit city idiot. There is no signal coming from the head unit. All that is is the controls for the real head unit which is in the trunk on the left side inder the trunk liner. You can get a good signal from the speaker wires by spicing into them. The key to getting a good signal from the high level speaker wires is getting a good line level convertor such as a pac that has adjustable levels so you can get a good low level signal to the amp. Also since you are running a sub amp you are not worried about any interferance as much as if you were getting a signal for the imaging speakers which then you could also use the speaker level inputs but you would want to get a sound pracessor to get a good clean signal to the amp. Do not go to circuit city or best buy for any intalls or questions. They only are trained to do it by the book and not research what is truly needed for a specific vehicle. By the way I have a mtx thunder 1000D (1500 watts) running two thunder 8000 12" subs and they slam with my line level convertor feeding the signal. The thing that I miss about haveing a head unit is the control of the system. If you have any other Questions just post them.
96 silver frost
18" asa js5 wheels
245/40/18 kumho esctas
bullet turbos 3 1/2" tips
open K&N filter
powerslot slotted rotors
asp underdrives
triple guauge pod oil,volt,water
http://cmurdersho.tripod.com
SHOntell
**** Rapids, MN US
cmurdersho, thanks for that post. I will go ahead and get myself another sub and amp. Not sure what size to do though. I may go smaller. With a kid, or three, having good trunk space is cruetial. Thankfully my wife got her Mazda 626 es V6 and she doesn't use/abuse the SHO anymore
I'll post if I have any more questions.
"I'll be Back"
W
whelen1
Guest
When I had my mazda 626...in a time long long ago, I used a RF converter off the rear 6x9's (or whatever they are) and it sounded fine, I am a little iffy about splicing in, but if it works for you and it sounds good, go for it.
As for subs, i have a 250 watt MTX amp with 2 10" MTX subs, and a Pioneer head unit running it all, and that has more than enough power to shake the living **** out of my trunk/rear quater panels....not to mention my fillings
[This message has been edited by whelen1 (edited 12-30-2001).]
XLSuruaT
HB, CA USA
I was searching and this thread seems to come close the the solution of my problem.
I have a 96lx duratec with the jbl premium sound system.
I installed an mtx 5400 (5 channel) amp. I used two (http://www.installedge.com/products/product_details.jsp?productID=1108) and an Image Dynamics 10" sub.
So far the 4 channels are great, but the sub is lacking some power. I am using the electronic crossovers in teh amp to power the sub since I am only using 4 channel input.
I was wondering what do I do now. I tried a Y cable which split the input of the rear to the sub input and the rear input..nothing. I tried running the sub off of the rear channels. I am wondering if for cuts out the lows and sends them all to them 6 by 9 sub. So, should I try and tap the signal to the sub before it hits the integrated amp?
My guess is with the dedicated sub woofer on the JBL system it is ran through a crossover somewhere.
BenBrausen
Minneapolis, MN USA
I just got a nifty lil' converter that attached to the factory amp connector and gave me 2 RCA's to hook the head unit up to. Line out from the headunit to the EQ and then front and back RCA's from the EQ to the factory amps. I'm gonna look into gettin' rid of the factory amps and get something with more power. Yank the factory speakers too. So much to do, so lil' money.
Chris Benvie
Every so often
RedSox Nation
I work at a Car stereo shop and i fix Circuit city's mistakes all da, get the line level converter, splice it to the rear speakers, and just go from there, you can do it and it
l sound fine
Tunez
NC, USA
LOL, you are now learning why many in the Car Audio business refer to them as **** Em Silly. :D
The good thing here is that you have been given the correct info here about the line level convertor. Also, like it was mentioned before, there is no signal from the back of the radio so hooking it up after the amp, which is in the drivers side of the trunk, or at the speaker is the ONLY option you have. Well that is unless the amp also had high level inputs as well.
Just for your info as well, here are the correct wire colors so you know which is right:
Rear Right + Orange/Red
Rear Right - Brown/Pink
Rear Left + Gray/Light Blue
Rear Left - Tan/Yellow
As for me, I hated the idea of using the factory head unit and did the custom install in the center console. Will be purchasing another radio and dismantling the factory piece and making a custom fiberglass dash kit while still using the factory heat/AC controls REAL SOON. I also have a 5" TV in the cubby hole where the ashtray is and a Box in the trunk that has a single 12" sub and the DVD player in it.
If you have anymore questions on what you need to do for anything else in the line of the car audio, security, or video sections, please feel free to ask. Been doing Car Audio for 14 years now and own a car audio business as a side money maker. :D
SHO Squall
Cedar Rapids, IA
Tunez:
Will this be for the manual heat/AC controls, or the digital/automatic controls? AFAIK, someone already built a replacement shroud for the manual controls for the OvalKill, but nobody has one for the automatic, which is what I think at least 80-90% of us have. Please let us know!
-John
XLSuruaT
HB, CA USA
Well so far, I think I have tried a line out converter from the rears directly into the sub channel.
Here's how I have the system wired. I went to a junk yard and chopped off the output wire where all the speakers connect to, then I purchased some pos turbo wire amp bypass cable (I modified it so that it acts as a socket for the output plug). I used the junk yard connector to plug into my RCU, then from there, I sent the 8 wires into two Install Edge "IEC AULOC Audjustable Line output Converter 2-60 watts" (one for the front and one for the rear. There were 4 wires left over from that plug that goes into the rcu, so I wired them directly to the turbo wire. From those converters, the signal goes into my amp, then from the amp it goes into the turbo wire. Then lastly, the turbo wire connects directly to the existing speaker plug that was originally in the RCU. I did this for the ease of wiring and the fact that I did not cut any of my stock wires.
I tried plugging the rca's from the converter for the rear directly into the amp, still very weak bass. I also tried using a Y adapter so that I give signal to the rears and the sub channels, but still the same results. I am going to double check the(3*25amp) fuses on the amp tomorrow mornign when there is light out. Also I was wondering what would happen if I take the signal on the jbl sub before it hits the built in sub amp then add a line output converter to that, then connect that to my sub input?
XLSuruaT
HB, CA USA
Ok, I narrowed it down now. Instead of checking fuses, I hooked up my discman to the amp. That was more like it. :D Now I need to figure out where I am losing the bass in the ford system. I have hooked up the rears directly into the sub channel and it still did not work. I am thinking of buying another line output converter, then tap the sub wires BEFORE they hit the sub amp. According to my service manual, the red/black is negative and brown orange is positive. I am wondering what the significance of the high audio mute is. If anyone advises against trying this, please let me know asap because I am heading to the store to buy the converter.
XLSuruaT
HB, CA USA
Ok, hooking up the loc before the sub amp did not work. So I tried after and that worked. I was wondering how would I analyize the preamp signal from my loc to make sure that it isnt going to hurt the amp. I dont know how many watts and volts are running from the jbl sub. The loc I have works from 2-60 watts and I used both channels on it for the sub, so I should be able to handle up to 120 watts from the jbl amp, right? But I doubt ford would have pumped that many in there. Any commentS?
Glebtihonniaqw
