Sub In The Trunk Hook Up
Funmart6
my name is mud
Auburn, Alabama
Okay I have the wiring color codes for the rear speakers and I have a wiring kit that should have all that I need to wire this thing up. I know I need to run a wire from the battery to power the amp that is built in to the sub (that will only power the sub). What I need to know is this, what do I wire this thing up to in order for it to turn on when the radio/CD/tape player is turned on? Are these things seperate? shrug What I mean is, I don't want this sub to only work when the CD player is used, or only work when the radio is on, I want it to turn on when any of these is on. Help!!!!! headbang I am confusing myself!!!! And I am sure I am confusing others as well. cry Thanks for any assistance!!!
DavidT
TN
my 97 REALLY lacks in the BASS dept. Even though it is the Mach system. What is the best way to add a sub? I like what you've done... the amp is built into it thumb
I am looking for decent/GOOD sound at a GREAT price.
Thanks.
Funmart6
my name is mud
Auburn, Alabama
Well DavidT this is just a 8inch tube style subwoofer by Audiovox that has a 200watt amp built in. I used to have it in another car a few years ago and it sounds great, you can buy them just about anywhere and they are not that expensive. Try Wal-Mart, I think I saw one like it there, it was just a different brand.
DavidT
TN
cool. I see circuit city sells them for $60. How hard are they to install with the factory Mach system. What do you have to do?
Thanks.
DavidT
TN
well, I bought it tonight... now... how in the world do I hook it up??????
Here is the pinouts of the rear radio/cd connectors.
DavidT
TN
wow! Thanks! thumb
BUT, do I have to run the power wire to the battery, or can I run it to one of the wires at the RCU? If so, which one?
If you mean the power for the new amp, yes you will need to run a new wire back.
MeeSHO
SHO Owner
York Springs, PA
As SHOZ123 said, you will need to run a new power wire from the battery to the trunk. There is a hole in the firewall above the fuse box under the drivers side dash. You can use that to run the wire into the car, then just hide it under the doors kick plates. You will still need a remote wire, which tells the amp when to turn on. I have mine on a constant power source, and have it switched, so I can turn it on/off when I want to. You can always find a place to hook the remote wire that is only on when the ignition or radio is on. Thanks SHOZ123 for the diagrams boink
<small>[ August 17, 2003, 06:17 PM: Message edited by: MeeSHO ]</small>
DavidT
TN
thanks.
The sub has a built in amp with 4 wire terminals. 2 for the speaker, 1 power, and 1 ground.
1.Where would the remote run to?
2.Why can't you use one of the existing power wires already back there... like for the factory amp, or the power antennae, or the cd changer, etc...?
btw, excuse the ignorance :cool:
<small>[ August 17, 2003, 08:52 PM: Message edited by: DavidT ]</small>
MeeSHO
SHO Owner
York Springs, PA
There are a few reasons to run a new power wire. The biggest one I can think of is that the amp is going to draw a decent amount of juice at volume. If you run lets say an 8 guage wire straight to the amp, from the battery, all the power on that wire is going straight into the amp. If you run it off of another power source, it is fighting with the other accessories for the power on that line. This in turn causes excess heat, possibly enough to melt the wires, which I'm sure are more like 14 or 16 guage (8 guage is bigger than 16). Picture this...try to suck a pea through a regular drinking straw. It's not going to work very well, and you are going to strain a lot trying to do it. But if you use something bigger than the straw in diameter, it will be easier to do and a lot less strain. Same thing applies for the amp, it is going to have to work harder to pull the current it needs through a smaller guage wire, plus fight the other accessories. And you dont want any melted wires, that will make things worse. As for the remote wire, I find it odd that it doesn't have one. The remote wire as SHOZ123 says could be spliced into the main head unit. Which is not behind the football, but rather above the rear left wheel in the trunk. However, it is possible that the amp will use the current coming from the speakers as the switch. No more juice from the speakers in turn would tell the amp to turn off. thumb
Funmart6
my name is mud
Auburn, Alabama
I want to thank everyone who has posted replies to this topic, you guys have been a tremendous help, now maybe I can get my sub hooked up after all. Thank You!!!! beer beer thumb thumb beer beer
The remote turn on wire is pin number two in the first diagram. The light Green and Black wire.
DavidT
TN
MeeSHO
SHO Owner
York Springs, PA
Do not splice a wire into the power wire, that would be a bad idea. You would just make the wire you spliced in another hot wire (electrified). If the sub is like the one in DavidT's link, in its description it says "Automatic signal sensing turn-on circuit". That takes care of your remote wire, because it uses the speaker inputs as the switch. When you turn your stereo on, juice from the speakers turns on the amp, and when you turn it back off, the amp should automatically turn off too.
<small>[ August 18, 2003, 04:37 PM: Message edited by: MeeSHO ]</small>
Funmart6
my name is mud
Auburn, Alabama
My sub has seperate remote and power wires. With the kit that I bought at walmart I have everything that I need now to hook this thing up. My kit included 20ft of 12ga power cable that already has a built in fuse and connectors, came with butt connectors also. So what I will do is simple. I will run the main power wire with fuse from the battery to the correct red wire on my sub, next I will connect the remote wire from my sub to the light green/black wire (audio system on) on the rear control unit. Then I will connect my right and left channel wires to the positive left and right rear speaker wires accordingly. Last but not least, I will find a local ground back there in the trunk and that should be it. I also picked up some line tap connectors for hooking up to the speakers and remote without having to cut anything.
Thanks for everybody's help with this, this should sound good in theory right.
thumb thumb thumb thumb
DavidT
TN
wow Marty, that kit at Walmart is unreal! Probably best $12 I've spent thumb
I'll let ya know how it goes...
FIREMT1977
