Struts and springs
SHOwned213
CT
i have some performance springs and struts on my turbo 91, and since no one wants to buy it im thinking about taking some parts for my 94, just to be sure, they will bolt directly up correct? also on that car they make a clunk when cranking the wheel, my best guess is the springs twisting then resting back in place. what should i do to correct the problem?
CerberuS
300 HP N/A SHO
Granby, QC, Canada
The shafts between your transmission and your wheel , transfers the power from the transmission to the wheel. (It has 2 spring-like rubber cones)
SHOwned213
CT
ok, i would have called those the axles, or the cv's or something, but no, its not that, i know what bad cv's sound like and you dont have to be moving for it to make the sound its making,
Minnesho
i was wrong
MinneSHOta
sounds like your strut bearings/top plates are bad, or possibly sway bar links.
