Strut Bearing Plates?
mosho93
Well-Known Member
Wausau, WI
I did a search and couldnt exactly find what i was looking for. what is the exact name for these? where can i get some? and what are some of the symptoms if they are going bad? TIA
hawkeye18
Sorta cares
Norfolk, VA
Sometimes they're called Mounting Plates or Strut Bearing assemblies. Symptoms usually involve power steering fighting back (bearings going bad) or a popping sound as you go over bumps coming from the top of the strut. They're a PITA to change unless you take the whole strut off. Once you do that, though, it's easy. Make SURE you get new bearings; those are important, they allow the strut to turn...
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
Agreed with above. I found it easier to get the bearings from napa, AZ, rock auto, and the mounts from Ford dealer. They are 2 different things. Your dealer will have a picture(breakdown) on their computer.
JEff
mosho93
Well-Known Member
Wausau, WI
Well, there is Intrax springs in the car now with stock struts that are worn out. there will be a set of Tokico's going in probably, Should they just be replaced then? or is something that is a must now?
Mels
SHOVELHEAD
Brookfield CT
Check with Mike Kopstain at Midwest SHO. Got a good pair of bearings with the rest of my suspension order there, and he's a real good guy to deal with to boot.
Shoman94
Maine
Spork said:
Monroe makes a kit part# 901926
Just got those today actually...getting done Monday along with an alignment. Hope it gets rid of my long time clunk noise.
--Jason
