Dirk37
Mr. Resourceful
While replacing my rod bearings I found I was without a torque wrench, so I did the stupidest thing I've done in years and purchased one at harbor freight. The first stage of torquing worked fine, it clicked at 24 ft/lbs. But when I adjusted it to 35 ft/lbs for the second stage it didn't want to click.
I stopped because it just didn't feel right to me, the nut kept going on and it wasn't getting much harder to turn which is almost always happens right before a bolt shears.
So I took the rod cap off and tried threading the nut onto the rod bolt to see if it was stretched, it threaded smoothly until the last 3 or 4 threads where it gets hard to turn, which is where I'm assuming it stretched. I did the same test on another rod bolt that wasn't over torqued and it threaded smoothly all the way to the end of the threads.
I feel like such a ******** but being angry isn't going to fix the problem.
So the question is do I take my chances with it or attempt to replace it?
If I do need to replace it;
How do I get the rod bolt out with the engine in the car?
Where do I look for new bolts? I have a parts engine but I'd feel better with new ones
