STILL WONT FIRE AFTER REPLACING CPS
MATT HOWARD
ST. LOUIS
WELL HERES MY PROBLEM, I HAVE A 93 ATX SHO W?125,000 MILES, AND ONE DAY DRIVING DOWN THE ROAD IT QUIT ON ME, I FOUND OUT IT WAS GETTING FUEL BUT NOT SPARKING, SO I CHANGED THE PLUGS, PLUG WIRES AND THE COIL PACK, STILL NO SPARK, SO I THEN CHANGED THE CPS SENSOR, TIMING BELT, AND WATER PUMP WHICH WAS LEAKING AND STILL NO SPARK, ANY HELP ON THIS TOPIC WOULD BE GREAT.
twr
whoohoo
half-way there, I think.
It's possible the the CCRM or IRCM (depending on the year) has gone bad - It supplies power to the PCM. Are you getting a CEL?? any codes??
As a courtesy to all, please do not use all CAPS. It is considered SHOUTING.
Since there is fuel pressure, the PCM should be getting power.
As for no spark possibilites: Coil pack, DIS module, CPS, wiring faults all come to mind.
Neither code will cause a "No Spark" condition.
Continue focusing on the previous list of possibilites for attention.
