white93atx
Your temp sensor might be going bad. It tells the PCM what temp the car is. My car ran ran like crao u til it warmed up. Could also be that colder thermostat.
Did you check that the secondaries are closed at idle?
Probably not that he put in a cooler thermostat. 99% of the time, when a thremostat dies, it dies open and the car will stay too cold. Just replace it, an easy job. Just go easy on those small bolts.
