roswell998
It will be appreciated if Scott Patterson also replies to this since he had given a very detailed analysis at some earlier date about the issue related to erosion of the plugs anodes and cathodes because of the reverse polarity as a result of the coil firing the plugs in pairs.
In a nutshell, he stated that it was necessary for both the anode and the cathode to be plated (it seems that the original plugs had 3 with anodes plated and 3 with cathodes plated and it was critical which cylinder each was installed in).
INFO THAT HAS BEEN RECENTLY SEARCHED:
Before replying, please follow the link below and see for yourself what I describe.
If you go to www.motorcraft.com and follow the menu choices to plugs for the '93 SHO (probably any year with Yamaha engine), clicking on the standard plug brings up the AGSP32FM as an standard service plug (which is what most people on this forum recommend).
HOWEVER, if you click on premium/platinum plug rather than standard plug it will show a chart with the AGSP32P-P (or AGSP32PPF6) as a double platinum plug and the AGSP32FM is shown as an alternative platinum plug.
BOTTOM LINE..........If the AGSP32FM is a single platinum plug with only the anode plated, do we run risk of premature failure because of excessive cathode erosion on the three which are operating in reverse polarity? If not why does motorcraft.com specifically list them as "standard" duty and then list the AGSP32P-P as "premium duty"?
Your responses will be appreciated!
