dstig1
OK, here's the issue. Steering rack blew a couple weeks back (driver's side rack seal). Find replacement rack at Autozone for $215 (Ford was another +$100). Replace rack. PITA, but managed to do it OK. Noticed vibration especially when turning right in parking lots (slow speed). I figured out that it was air in the line easily enough, so I figured it was one of two things (the ONLY two things I touched) - the PS fittings to the rack, or the PS cooler hoses as they were kinda hardened and cracking a bit. Today I chopped off an inch of the PS cooler hoses and reattached them (nice flexible section now), and tightened down the main PS lines to the rack. Still I have air. I have not tried Ford/Helm's bleeding procedure (only tried the one that came with the American Remanufacturing - AMI - rack where you turn the wheel lock-to-lock 40 times with engine off) as I am not currently set up to do the vacuum bleeding procedure they discuss, but I could be, if needed.
I get the feeling there is a fitting that is not quite tight allowing air in, but there is no fluid leak anywhere. I only touched the two fittings to the rack, and the hoses to the PS cooler, but they have all now been rechecked and reworked. I was afraid of overtorquing the fittings at first, but I gave them a good bit more today (they said 15 ft-lbs which ain't much, but what idiot puts a torque spec on a fitting that can only be turned with an open end wrench?!??!)
I am not unfamiliar with car work as I have done everything on this car from new (including a clutch), so I don't think I am too much of an idiot. The car is 12+ yrs old, so I am looking more for "keeping it going" and not "cranking it up" here.
Annoyed and looking for suggestions!?!?!?!
-Dave
'92 5spd, 138k, some mild mods
-Dave
