steering column and the ignition system
carterh
Calgary Alberta
I hate to be the one to say this, but first off you are in the wrong section, and second you should really try searching first.
Cheers and good luck :)
artsho
New York
Remove the plastic cover from the column.......now look under the ignition switch and you will see a little hole......with the key on insert a small drill bit into the hole and while pushing in on the pin remove the switch.....
artsho
New York
carterh ...... ease up...... why is this the wrong trend....ignition switch is electronics isn't it....
Ferendon
Fort Worth, TX
Wouldn't say drill bit, that might confuse him. Would be kinda funny to see his drill it out lol... Not to be mean. Just put the key in, turn it to the "Run" position, and use a small allen key or something to push the locking pin on the bottom in, and pull out on the unit. Takes about 10 seconds.
