Started Rod Bearing Replacement ...question(s).
Rockledge
Pluggin' away
Connecticut
Well, this afternoon I started the rod bearing replacement job on my SHO. So far it has gone pretty well. I was able to get everything apart and opened up without breaking anything or stripping any nuts or bolts (some patience and a ton of PB Blaster helped!) thumb
I'm at the point now where it's time to do the actual replacement of the bearings, and I will be getting back to that tomorrow morning.
However, after pulling the pan I noticed that one of those quarter-sized holes located near the top corners of the pan was actually about 60%-70% blocked by a wad of old gasket sealant that had apparantly oozed into the pan area the last time someone had buttoned it back up.The holes I am talking about seem to run up into the motor.
My questions, therefore, are as follows:
1) Where do these holes go to? Are they the oil return holes I read about in this thread?
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=17;t=008847
2) What kind of damage, if anything, should I be concerned about as result of this blockage?
Thanks for any feedback.
qiksho
SHO Addict
Fargo, North Dakota
I would assume the hole you are referring to is a return hole. THus it being partially blocked won't create any HUGE problems. However it may come into play if you ran the car really low on oil.
Yes, those are the oil drain (return) holes from the valve train area to the oil pan. There are two holes per head and as long as one is open there is a path to return the oil to the pan. There will be more oil than normal up in the valve train area before it can find its way back to the pan. Since there was some flow past teh blockage, there was probably no problem. Just use tweezers or a hooked wire to pull the silicone from the hole.
Rockledge
Pluggin' away
Connecticut
Thanks for the replies. Read them this morning before I headed out.
I replaced the rod bearings today and finished putting everything back together ...looking forward to adding the oil and starting it back up tomorrow morning!
I took my time with the bearings, and didn't really run into any problems with them. A few of the upper bearings were a little hard to get at, but I managed. Quite frankly, one of the biggest challenges for me was trying to keep everything clean!
As for the pan, I followed the tip about using that copper gasket spray stuff to hold the end gaskets in place, and it worked well...the key for me was to let it get a little tacky before applying the gaskets.
I also took some pictures. Here is what the old bearings look like (the bearings in the bottom picture correspond to the cylinders in the top picture, left to right):
It looks to me like the lower bearings were wearing a little more than the uppers, and there is really only that one bearing that shows a more wear overall, relative to the others.
But I would like to hear what you guys and gals think?
<small>[ October 18, 2003, 09:24 PM: Message edited by: Rockledge ]</small>
Ishodu
Wow they look worn. Are you sure you didn't get the upper and lower ones mixed up? Usually the upper bearings show the most ware.
Rockledge
Pluggin' away
Connecticut
Ishodu:
Marcel,
That is the same thing I was thinking to myself when I was taking the old bearings out ...how peculiar it was that mine were showing more wear on the lower side (the lower side is the one with the bearing cap, right?)
In fact, I made a mental note of it because (1) I remember looking at pictures of Scott's old bearings which showed more wear in the uppers, (2) I've read a few posts wherein other people have generally described more wear in the uppers, and (3) I knew I would be asked about it later like this wink
Do you think that the lowers wearing more than the uppers is a sign of anything? Is it that I'm not revving the engine high enough, or something like that? lol :D
Also, FWIW I did not find any shims, shim tools, or sockets in my oil pan. :D No metal shavings either ...there was only that dirty oil "film" that you would expect to see at the bottom of any oil/tranny pan.
Rockledge
Pluggin' away
Connecticut
Well, I started up the SHO this morning while holding my breath at the same time. wink I let it crank a few times before actually starting it in order to get the oil flowing a little bit.
The engine sounded fine when I started it, although it was a little smokey at first due to the oil, PB Blaster and anti-sieze that had been splatttered about during the project. I let it warm up and then got on the highway, took it easy for about 5 minutes, and let it fly ...nice and smooth! Maybe it's just my imagination but it seems a little smoother now when I downshift and let out the clutch when slowing down.
Checked the pan again after the ride and no leaks (so far). Everything looks and sounds good to go! :D
So, I hereby give a big thumbs up and thank you to everyone who takes the time to contribute to this forum, providing info and guidance which allows people like me to tackle a project like this. thumb hail
P.S. I am still interested in hearing from anyone who has an opinion on the condition of the old bearings....
jelloslug
Digital
Greenville, SC
That is very odd, I just did my rod bearigns this weekend and all the wear was on the top (rod side) of the bearings. I guess it could be from lugging the engine or from poor maintance from the PO. My engine seem to be smoother also, I don't think it's in your head :D .
tracy_s_1993_atx
Plano, Texas
Wow that looks easy????
Are the rod bearings that easy to change?
My 93 ATX has 108k miles, should I change the rod bearings?
What is involved in changing the bearings? What special tools are required? Where did you purchase the parts?
Thanks,
Rockledge
Pluggin' away
Connecticut
tracy_s_1993_atx:
Thanks,
IMHO, the job is relatively straightforward, but it is also somewhat time-consuming, especially for someone like me who likes to take his time.
To give you an idea of the time involved, I spent all of Friday afternoon (from 1 p.m. on) taking everything apart, spent all day Saturday changing the bearings, cleaning and prepping the oil pan and reinstalling it, and putting everything (starter, Y-pipe, etc.) back together, and spent then a couple more hours Sunday morning hooking back up the battery, securing the oil filter, adding the new oil, "priming" the motor, and then ultimately starting it and giving it a test drive.
Here are a couple of excellent online resources that I utilyzed:
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=17;t=004979#000016
(scroll down to sdpatt's post containing his writeup of the rod bearing replacement procedure)
http://www.kurtmetros.com/bearings.html
(...almost forgot to add that I made another small PayPal donation to the SHOforum on account of the great info that was avilable for this project...)
thumb
<small>[ October 20, 2003, 10:39 AM: Message edited by: Rockledge ]</small>
All loads from the expansion of the combusted air/fuel mixture are applied to the bearing on the top of the crankshaft and will result in greater wear rates of this upper bearing surface. Those bearings looked more worn than the bearings I removed from my engine at 269,000 miles. Here is the topic where I posted the step-by-step procedure for the bearing replacement. You can get the standard size, Clevite CB1435P bearings from NAPA for $44.94 (6 sets).
DHMag
Free At Last
InCahoots, Texas
tracy_s_1993_atx:
Thanks,
it is a straightforward job. from beginning the time i put the car on ramps to the time i backed it off the ramps, 5.5 hours had elapsed. my old bearings resembled 99% of the others ive seen, copper showing on uppers, average wear on lowers. i did mine at 120K.
Rockledge
Pluggin' away
Connecticut
5.5 hours to do the whole job?! eek! That's quite remarkable!
It took me 4.5 hours just to take off the Y-pipe, disconnect the starter, and drop the pan! headbang
I guess I better not quit my day job!! lol :D
DHMag
Free At Last
InCahoots, Texas
Rockledge:
y-pipe had been removed at a previous time so i didnt have to deal with rust. then again, my car has been in Texas all its life. only place i had any problems was wriggling the pan from its location.
Off Road SHO
Moderator
Rockledge
Do you think that the lowers wearing more than the uppers is a sign of anything? [/QB]
Yes, it's a sign that some cheapskate that owned the car previously decided to flip the worn side down to the bottom position.
The only other way that I believe that could happen is if the driver does a LOT of hard down shifting. Wouldn't that put the slam to the other side of the journal? I don't know enough about this type of thing.
Tom
SolidState
No Mo SHO
Toronto, Ontario, Canada
Rockledge:
Not including the back tracking marcel and I did, we would have done mine in about that...
Rockledge
Pluggin' away
Connecticut
Off Road SHO:
Rockledge
</strong>Yes, it's a sign that some cheapskate that owned the car previously decided to flip the worn side down to the bottom position.
Tom
Tom, I'm no expert myself, but I was thinking the same thing ...I am fairly certain that the oil pan had been dropped before at least once for some reason (I could tell that just by the way it had been re-sealed and by the fact that the "old" rubber end gaskets on the pan were almost brand new), and maybe that's when the swapping of the bearings could have occured.
Not exactly the place to be cutting corners, wouldn't you agree... :rolleyes: ... makes me even more glad that I did the job. :cool:
FIREMT1977
