Rogue10186
The Cajun
Ok when I started my car yesterday a weird Squeeky noise came from the area around the pasenger side firewall, it squeeked about 3 or 4 times, then went away. It now does this all the time when I start the car from a cold startup. The squeek only occurs (from what I can tell) after about 10 to 30 seconds after the car has been started with the engine cold. I can never hear it while driving around, only on a cold startup.
I know that I have a coolant leak commin from somewhere in the nether reaches of the passenger side firewall, and that the coolant is burning up on one of the cats (makes me wanna
everytime I look under the hood to figure out where it's comming from).
Could this squeek be related to the coolant leak, as in when the car is started, it pushes the air in the line from the leaky spot out, then continues to leak coolant?
everytime I look under the hood to figure out where it's comming from). Could this squeek be related to the coolant leak, as in when the car is started, it pushes the air in the line from the leaky spot out, then continues to leak coolant?
