the coil on plug design eliminates any problems with shorted plug wires and deteriating insulation. I would stick to the Ford plugs only.
Shawn Pasley
Innovative Performance Technologies
92 SHO red/grey
3.2L Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal lenght Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/Sho shop linear springs, poly-bushings everywhere, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 comp T/A ZR's on TSW VX-1's. 15 lbs of boost here I come!
