Sound coming from trunk
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I have sound of rattleing metal coming from the trunk of the passanger side. I was reading some past posts that it could be strut mounts or rear sway bar bushings. I doubt it is bad strut mounts because I have konis and the strut tower bars. So I am guessing I just need to get new bushings. Would it help to get the SHO Shop 29mm sway bar while it is being taken car of?
93nighthawk
Mitchell, SD
Do you have Ford Premium sound? If so I would pull the black wall stuff in the way back of the trunk and see if one of the amps came a little loose. It would make a similar noise, and is a cheap fix.
Eric
