revhardSHO
My 89' SHO is giving me some trouble. Engine will start fine and idles normally. From idle(in nuetral) if you hit the gas it will bogg for approximatly 1/2 second and then spool up. It seems slower than normal to spool and has less throttle response in general. And its drive-ablitity has gone further out the window...
Now for the "moving" symptoms. In first throw 5th gear from ~1000-3400rpm ive noticed hesitation and inconsistant miss-firing. These symptoms occur under normal accelertion, and get worse under heavy acceleration.
At low rpms (1300-2200)under WOT the engine will backfire, and you'll hear the classic "POP" from the airbox. Hesitition is ALOT worse under WOT.
Now here is the strange part. Once the engine gets turning over ~3600rpm there is much less hesitation and virtually no missfire. Alot smoother has good power. although it does feel slightly weaker. The engine has 100K on it and there is no oil in the plug wells. the CE light is on, but i think the O2's are throwing codes. Im not about to go outside w/ a paperclip and flashlight to run the codes, maybe tommorow if it warms up...
and addvice would be appreciated.
thanks,
silas
<small>[ February 12, 2003, 08:30 PM: Message edited by: smithsil89SHO ]</small>
thanks,
silas
