Jamz SHO 813
OK here goes. 93 MTX 101K. Coming home from school last week and as I go to put it in 1st gear I push down the pedal and attempt to shift into first. No good. So I take my foot off the clutch and try again. This time pedal stayed on floor. I reach down and pedal is floppy. Clutch cable snapped. Get it towed and have it fixed by the next day for $200. $125. for part $75 for installation. Pick the car up that night and everything is fine. Shifts really nice and smooth. Next day I go to work and did a few delivieries and pull into a parking spot. I wasn't quite straight so back up, as I let off the clutch the whole car started bucking and I thought the engine was going to come through the roof. Get it under control and pull into the spot. As I leave I ride the clutch out and it stops the bucking. Next morning go back to mechanic and he says, "Hey I forgot to tell you that it's bucking in reverse!" "Thanks I know. Whats the problem?" He said it could be a bad mount. But I just had all 3 replaced about a month ago. Also if I let off clutch too fast in first I hear sort of a growling vibrating bark for a quick second. Do you think it has anything to do with the tow truck pulling it? I'm confused. Anyone have expirence with these symptoms. Anything would be a help...
shrug Thanks
shrug Thanks
