"Sludge" / REALLY wierd deposits in oil pan
Yamaha V6
SHO Enthusiast
Rhode Island
I have a customer who's going with a 3.2L conversion this weekend. I needed the 3.0L oil pan, so after pulling that off the old engine, I discovered an almost "greenish"-tint, but black semi-fibrous, soft & squishy where oil-wetted, hard & crusty where not oil-submerged "residue" (piles of it, actually) all over the inside of the oil pan, & up by the oil pan gaskets, completely blocked off the pickup tube screen & the oil level sender.
Customer had a spun bearing engine (and Ford Dealer "couldn't help him"), which I originally suspected was a bad oil pump. Well, looks like it was oil starvation, but maybe not a failed pump as the root cause.
My gut feeling is that this is some kind of stop-leak that someone added to the pan before he bought it last fall. Anyone else run into this?
I'd post some pics, but camera's down.
Oh, BTW, Berryman's is afraid of this stuff. Hardly touches the crusty locations, & works so-so on the clumpy wet stuff. Embedded in the clumpies & crusties are lots of copper flakes.
"Copper Flakes... the new cereal of SHO owners from Kellogg's"
rendyx
Buffalo, NY
The stop leak theory sounds pretty possible to me. Either that, or something got down there that shouldn't have. But considering the unwillingness of the milk & cereal ( :p ) to be cleaned out, it seems like something designed to stay on a spot, like a leak stopper.
Give us some pics when you can, it'll be interesting to find out more about this, and maybe we'll find out what NOT to use in our engines. Good thing the guy is getting the 3.2 swap done!
Hubes
Burl., MA/Chesapeake, VA
fred, could it have been coolant mixing with the oil to make it a greenish tint? i know way back when my dirtbike's head gasket went and coolant leaked into the cutch casing causing the oil to almost turn kawaski green (it matched my bike :) ) i am probably not right about this incident though
rangerj
Brunswick, Ohio
Yamaha V6,
That sounds exactly like what I found in an engine where the owner insisted he never, ever, used anything other than Quaker State oil!
I've heard of folks putting sawdust in a trans, or an engine, to quite down things like rod knock, or grinding gears in a trans, just before they trade or sell the car.
Maybe the owner PO'd somebody, like the last mechanic that worked on the car. A neighbor of mine had a dispute with a shop over the engine rebuild charges. Six months later his engine was trash.
Sand was found in the engine oil. He sued the shop. The judge awarded him a full refund of $2,500, but no other damages. His legal fees were $10,000, which included lab fees and expert witness fees. Go figure! rangerj
Yamaha V6
SHO Enthusiast
Rhode Island
I took pics of the crud & what's left in the pan after 8 cans of Berryman's, and of course, left the camera at the shop.
Jay - the tint isn't THAT green. If the HG went, the oil'd be pretty loose.
I suspect previous owner did something to thicken the oil perhaps, or used a stop-leak. Come to think of it, you know that "rubber" stop-leak for radiators? It acts like that stuff, loose in some areas & thick & solid in others. Hmmmm.
Yamaha V6
SHO Enthusiast
Rhode Island
Here are the pictures. Last one is after 14 cans of Berryman's, a brass brush & some rag wipe-down.
This one is after 24 hours of being submerged in B-12. Note the stuff is still not liquidous, more like the consistency of hand cleaner.
If you look closely in the other pics, you'll see the tiny "flecks" of the copper bearing. The pickup tube screen is clogged with this sludge as well.
Other pics:
http://www.neshospecialists.com/images/oilpan_crud1.jpg
http://www.neshospecialists.com/images/oilpan_crud3.jpg
http://www.neshospecialists.com/images/oilpan_crud4.jpg
http://www.neshospecialists.com/images/oilpan_during.jpg
Heathcotejosh37
