SHO won't start...some help?
steevil
Edmonton, Alberta Canada
SHO left me stranded at work. $75 to get it towed home. argh!
hop in, put the key in and it turns over. Won't run. CPS?
I don't own a code scanner so I have no idea what is wrong.
Sounds like a classic CPS failure?
1, how much does a new CPS cost?
2, DOes anybody have a pic of where the CPS is located?
Thanks folks!
autobahnsho
SHO Victim
NY for now, WY for real
steevil:
Thanks folks!
See Shotimes.com to run the codes without anything more than a wire, pen, and piece of paper.
Basically you put a wire in the test harness (under the hood above the strut near the passenger window), turn the key on, and count how many times the check engine light blinks.
As far as the CPS, does it ever "hiccup" (stall for a second and the tach drops) while driving? Mine did.
The CPS is less than $40 @ Autozone.com
It's located right next above the crankshaft where the belts are all driven from. You have to take off the pulleys, timing cover, and belts. To pull those off you remove battery, part of the intake, the liner under the passenger fender, wheel, and other assorted junk.
I just did mine the last 2 days. It would have taken less than 6 hours except for a few VERY stubborn bolts/screws, putting most of it back together to realize the timing was off, then getting it almost all back together to realize I forgot a part on the crankshaft and had to take it all apart again.. : :mad:
Contact Scott P. because he has a lot of info on this. Except he'll tell you that the CPS is $34.99 but the price has gone up recently.. :D
Good luck! :D
steevil
thanks for the info!
Car was running fine. Shut it off..went to work go to start it to go home...nothing.
I guess I'd better pull some codes first and see what gives...
autobahnsho
SHO Victim
steevil:
That's what mine was doing, too. One minute it works, next it doesn't.
The codes will help a ton. Now that I know they're so easy, I'll definitely run them anytime something seems fishy..
steevil
Replaced cam position sensor and CPS. while I was in there, I did the water pump and timing belt.
HUGE job but the car runs like a champ now! Thanks for the help folks!
