SHO on FIRE
needaQuaife
AKA: 5speedSHO
San Diego
Coming from work on Tuesday 5/11/10, SHO started to stumble. Pulled into gas station, popped hood and smoke & fire was already there, then popped trunk and two dudes ran up and sprayed it with fire extinguishers.:fit:
I had to take trolley home. The cable shorted & burned itself into the battery. Tried to push start, but, no start. I hope it fixes with battery and cables. Flames were a couple feet high and I thought for sure the SHO WAS GOING TO BURN.
5/13/10 Put in a new battery & cables... :pray:The SHO LIVES!!! :woo-hoo:
5/14/10 It's running, now to go 4 a drive...well, this morning I removed the battery to reinstall the battery tray. started her up and 300 ft later engine cuts out. I freaked :doh:, I was thinking Oh NO, not again, popped the hood and smoking again (ground strap from intake to firewall started to burn) . Luckily, my new trusty Quick release post clamps worked in a jiffy . Seconds later smoke stopped. I was already running late to work @ 4:30Am & it was too dark for a closer look. This morning I returned, (boss gave me the day off, Its my birthday) , the new battery + post was touching the hood. Remember, the battery tray lifted it up an inch or so... I put a dozen stips over post and over spot on hood where they intersect. Like new again!
So, i just have to redo whole battery and cabling, otherwise, I am good.
What is the exzact height of ya'lls battery. ( from the bottom of battery tray,to the top of the post)?
green95
green95
Sebring, Florida
I was thinking the same thing! First the white one, then mine almost burned, now this one. Stuff happens in 3's so hopefully its over.... Good thing you got the fire out.
mattsho1993
SHO owner
albion, new york
When i bought the '93 ATX it was on fire previosly due to master cylinder recall plug had to swap everything in that area. Booster, master, and i made sure to get the recall done!!!! My 94' the battery almost did the same thing it was hit on that side which pushed the tray up so the battery touched the hood. So i beat the ***** out of it and got it to go back down....
needaQuaife
AKA: 5speedSHO
San Diego
I had put in a twin oil filter relocation kit. the battery went in the trunk. So, the cable was under the kit and chafed, causing a short and burning all the way to the trunk, setting the rear seat and trunk liner on fire. My bad, but upon inspecting all wiring, noticed most cable/wiring insulation is also cracked, brittle and or just needs electrical tape or replacement.
green95
green95
Sebring, Florida
I should've let it burn and collected the insurance money. I will measure my battery tomorrow for you. My car is sitting at the dealership I work at so it will have to be tomorrow.
white93atx
pa
The insurance company with question you for 45 minutes about why it burned ,were it burned,when it burned. My favorite question was why did it need towed. Glad you got the fire out. I don't ever want to watch my car burn again.
notbange
Love fiST
Sale Creek TN,formerly MA
What group size battery did you install? It's supposed to be a group 34, I've had various brands of 34 and they all fit just fine. Most recently an Interstate in the ATX, and a mopar battery I dug up at work that holds a charge alright in the MTX.
needaQuaife
AKA: 5speedSHO
San Diego
I am going to exchange it, shop must have sold me the wrong one. The battery tray is snug & level on fender. i just measured and the top of the post sits 2" 1/2 inches above the foward crossmember above the headlights.
green95
green95
Sebring, Florida
I don't see why you had it towed either....:nut:
HotRodKid
mmmmm ... turbo
Western NY
i see their point, you shoulda just manned up and drove it home ...
and people wonder why i treat insurance adjusters like they aren't people. My opening line to the ins copany about a friends RSX-S was "im calling to find out what blind bastard without any brain function wrote my friends estimate"
mattsho1993
SHO owner
albion, new york
My MTX was vandalized keyed and smashed windshield i had full coverage... The insurance loss person came out and wanted to total it said my "Taurus" was not worth repainting i was like get the FUkkkk off my property i flipped... So the dropped my coverage to liability so i dropped them... Primed the car replaced the windshield so now it sits in primer ;(
tardboy21
Woodbridge, NJ
The thing about owning a cheap a$$ car, is that if anything major happens it is likely totaled. That's why I have two. Not the insurance adjuster's fault you have a 17-year-old Taurus worth at most a couple grand.
white93atx
pa
I told her the keys melted and 3 of thr tires burned off. They think Iam going to torch a 93 taurus with my daughter in the car for money.
HotRodKid
mmmmm ... turbo
Western NY
right cause noones stupid enough to do that ..
wait ...
and thats not a shot at you, its just a shot at humanity in general.
