SHO Nut FPR Setting with PowerDyne Setup
BigCaney
N.E. Ky
Well after a long time off the road installing a PowerDyne setup, my SHO Plus is almost ready to roll again.
I am running a Walbro HP255lph fuel pump and F4SE Blue top 36lbs fuel injectors. I am having trouble getting the motor to run. I am curious to know if my SHO Nut Fuel Pressure Regulator (basic kit) should be set at the stock setting of 39psi or at a different psi setting ???
Thanks for any help or suggestions.
-Mike :)
Ishodu
Unless your running out of fuel as in injectors are hitting over 80% duty cycle just set it for 39psi relitive. The instructions are all on his site if you need them.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Pretty sparse info there Chief. What exactly is happening? What means are you using to tune it? Got spark? Got fuel? Anything else recently installed, or just the fuel system components and the SC?
BlackonBlack89
burlington county,NJ
If u just threw the injectors in it won't start. Anytime u change the injectors u need to tell the the computer. Unless u have a tune already. But like toolman said we need more info.
91PDXmocha
Portland , Oregon
I have been working with the same injectors in my turbo car . Like others have said you need a tuner to change the injector values . A tweecer or quarterhorse will get you running again . If you need help finding values for the 36's pm me .
BigCaney
N.E. Ky
Running Now
Not exactly what was going on, but it seems to be running like a champ now.
I have a few more things to do before I can take the first road test, but it sounds great, starts great and takes the fuel great. I only hopes it does as well on the road as it does on the jack stands.
Thanks for all the input.
- Mike
Satchmoz
