SHO no starty no more
705sho-off
Fenelon Falls
As I mentioned in another thread, I have been having some major headaches right now with my SHO.
As a matter of fact it may be up for sale real soon (I miss my Tbird SC...although Im sure once it is up and running again I will fall in love for the 3rd time)
I replaced the water pump on my 92 SHO. After that, the car wouldnt start. So I bought a new CPS and replaced that.
Still nothing.
Now it is over at my mechanic's awaiting surgery, and he isnt really to sure whats wrong with it either.
He said possibly the DIS module, any merit with that or am I about to waste a few more hundred dollars here?
much thanks.
ghostrider
Mt Juliet, TN
Have your mechanic check double check and tripple check all the grounds. If the DIS is not grounded the you won't start. Have him check for spark, fuel pressure? My guess would be a ground was missed probably. That what a lot of the no start issues are. There is an intake strap that grounds the DIS.
projectSHO89
SHOless In St L
If you had the timing belt off, you may have put it on wrong. See the other recent thread titled "SHO won't start after timing belt replacement- Please Help!!!!! "
Steve
<small>[ June 03, 2002, 08:31 PM: Message edited by: projectSHO89 ]</small>
myculito
