SHO Components for 914 build
Shovert
ky
Found the tan/red. It is in 16 pin square gray plug with 15 wires. It has one blank [no wire] spot. The other wire probably is not in the engine harness. The red/yel also powered the tach in dash. So it probably never got into the engine harness. Maurice
3d914
Maurice, thanks - pin #17 is sto/mil so that one is a match. The other wire I'm looking for, T/Y ties into the PCM harness at pin #4. I checked the three 16-pin inline connectors I have wiring diags for (C101, C104 & C122). C122 does have a single unused pin. It also appears to have the T/R from the PCM (pin #17) and the T/Y from the PCM (pin #4). Can you verify the T/Y for me?
TIA.
Shovert
ky
The c101,c104 and c122 makes no sense to me. My diagrams do not have those labeled. Can PM me them may help. I will check on pin 4 and see. Maurice
Edit Pin 4 t/y to gray plug mention in other post. Wiring diagram say to tach. Wire also goes to ignition control module but it changed color to gray/orange some where.
3d914
Maurice, thanks. Can you verify that your harness agrees with the wiring diag for Pin #4?
For reference I've attached pic of inline connector in question.
attachment.php
Shovert
ky
Yes This is my view from rear of plug or in my case looking at the body side plug. [I have body plug] Thanks for the picture I printed it for my book on my project. [Yes some of us still do it by paper] Maurice
3d914
Ditto Maurice, - I'm maintaining a book on this project as well.
The 3.0 wiring PCM diagram indicates the Data Link Connector is on the PCM cover. Is this the same as the ODB-II port? If not, what harness is the Odb-II port tied to?
3d914
Excellent. Thanks for the heads-up. I figured there'd be a chance since our 98 Windstar had ODB.
So at this point it looks like I have everything accounted for. Many thanks.
3d914
Maurice, I need some details from the ATX harness you posted earlier. I need the pin#/wire colors for the two connectors enclosed in the yellow square. I need the info for both the female connector (on the engine harness) and the male connector (on the ECM/component harness).
attachment.php
attachment.php
TIA.
Shovert
ky
Will work on it. It goes from section of engine harness to other section of harness. Maurice
Off Road SHO
Moderator
Uh, I don't think they do. There are tw sets of those type of connectors on the engine compartment harness. The set that is closest to the PCM plug are always plugged into the engine's harness, ATX and MTX. The set that is underneath the throttle body, I've never seen plugged into anything.
Tom
Shovert
ky
I am unsure now. Because on left side near the PCM is 4 connectors. Then these 2 on trans side. Then the 2 I got plugged together to the harness. Took this video as can see both sets are plugged in. Wording is wrong on link. Wife does crochet and I sometimes get it downloaded with wrong name. Maurice
http://s177.photobucket.com/albums/...ction=view&current=crochetprojects2011003.mp4
Edit Right 2 plugs. Black one Purple/orange, black/green, brown/white, green/white, red/black, orange/yellow total 6wires
gray one Yellow/red, gray/red, gray,white, green/purple, blue/green, white/red, red/white total 7 wires
Shovert
ky
I tried to edit my first and timeout.
Two right plugs Black Purple/organge, black/green, brown/white, green/white, red black, orange/yellow. total of 6 wires
Gray plug yellow/red, gray/red, gray/white, green/purple, blue/green, white/red, red/white. total 7 wires.
Colors match across plugs.
Maurice
3d914
Maurice, Thanks. That the correct coloring for both connectors as compared to my harnesses here.
So what I need is to verify the destination of each wire on the component harness side. I tried to identify some of them listed here, but need to verify what I have & complete all wires.
From what I can determine so far, the grey one has some wires that go to the instrument cluster, and the black ties to engine controls.
Shovert
ky
Well darn. I just realize I double posted. The site came up time out screen?? You need to know where those 2 black and gray connector wires go to I will try tommorrow. Suppose to be 60 degrees outside tommorrow. I am going to try and get bunch done to mine but will let you know. Maurice
Shovert
ky
Black and gray connector that is on trans end. Opposite computer.
Gray One
gray/red tps, knock sensor and other items.
yellow/red knock sensor pin 23 at computer
gray/white tps pin 47 computer
red/white 1wire push on connector Coolant sensor to gauges
green/red ECT engine coolant sensor Pin 7 computer
blue/green rear o2 sensor #2 Pin 43 of computer
white/red 1 wire push on connector Oil pressure gauge
Black connector
green/white vss sensor Pin 3 computer
brown/white vref tps & egrsensor [pfe] Pin 26 computer
red/black o2 sensor #1 Pin 44 computer
Orange/yellow vss Pin pin 6 computer
Purple/orange hot for 02 sensors.
3d914
Got some more questions on the PCM wiring. I traced everything on the MTX PCM harness this weekend and all looks good except a couple of minor oddities.
  1. Pin #41 (Hi speed FP) does not tie into #22 (Low speed FP), but goes to CCRM at #11. In my PALVIN wiring diagram there is no #11 on the CCRM.
  2. Pin #40 & #60 (Gnd) are shown connecting. I have two wires-into-one (see pic) then into a round 1-pin connector. Where does this connector mate? It's must be on the body somewhere.
image.php
Off Road SHO
Moderator
Gerard,
There is a mating connector to that round one on the negative battery cable. As long as those two wires get back to Battery Negative, you'll be good to go.
I don't remember dealing with the high/low fuel pump issue; can't help you there.
Tom
myculito
