Sho 98 - imrc
lmccei
CA
Anyone know where I can find (buy) a new or used actuator cable assy? Part # F6DZ9L492AA. Tried the dealer route nationwide (ford part system). I'm new to this forum and (relatively) new to this model SHO - understand this is a common problem and a hard-to-find part. Any tips and tricks much appreciated. Thx.
SHO U UP
SHO Guru
Virginia Beach, VA
Local junkyard or you can also use the IMRC off a SLO that has the 24V Duratec motor also. One of the 4 bolts bolts don't line up on the valve cover IIRC, but I have used one before and it operates just fine.
lmccei
CA
Thanks guys.. already started checking the junkyards but no luck so far. May try the SLO..
SuperHO
Mental Patient
St. Joe, MI
meh, save your money, wire the secondaries open, reset your computer and enjoy.
lmccei
CA
OK - thanks. Looks like someone has a used unit for a decent price.
stephen newberg
Ladysmith, BC, Canada
If you look about on V8SHO.com, I suspect you can find a good description of how to do the job. I do not remember if there is one there with photos, but there might be. Its not hard, just requires twisting about in tight spaces with your hands a bit.
pax, smn
