shifter seems loose
92silverbullet
wi
I have a rod shifter and sometimes it grinds when i try to put it in gear. could there be a problem with the tranny itself such as syncros or pilot bearings or maybe i need a part for the actually rod shifter as it does seem to be sloppy.. any help would be great
spazmoid
RI
Have you looked under the car at the entire shifter support? The second tube on the shifter, the support/brace piece, broke right in half on my car because it was so rusted and i went down the drag strip with ****** motor mounts. The shifter got really sloppy then because that support had separated and wasn't holding the shifter in the right spot.
92silverbullet
wi
loose linkage
yeah i looked underneath and the rod shifetr is loose. seems like a prt under the black box is worn..
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
One thing that I just found with the 92, is that inside the shifter box, that there was alot of play where the shifter cup attaches to the transfer rod, the factory crimped connection was loose causing the shifter to move side to side alot more, and forwards and back, removed hte shifter and rod, welded the crap out of it, and there is no more play there any more.
zak
east of Hartford
Sometimes difficulty in getting into gear may be caused by clutch diaphram finger wear. When the fingerws are worn the clutch does not relase completely. What is your clutch setup and how many miles do you have?
zak
